Reverse Switch/ Wire
I want to install a rear camera and I need a wire to tap into when I put the gear in reverse?
When I installed mine, I tapped into the reverse wire under the center console. I fed the wire from the camera to the console, made the connection there and then switched over to the feed to the auxiliary input on my GPS unit. It's a green and brown wire.
