-   Audio/Visual Electronics (https://landroverforums.com/forum/audio-visual-electronics-10/)
-   -   weather band ??? (https://landroverforums.com/forum/audio-visual-electronics-10/weather-band-79161/)
XCELLER8 May 4, 2016 09:48 PM
weather band ???
does anyone know of an aftermarket radio that has the weather band in it, that will fit the D1 ??
binvanna May 5, 2016 12:35 PM
A lot of amateur 2 meter radios have the weather bands because the weather channels are around 162MHz, and amateur 2 meter frequencies are around 144MHz, both in the 2 meter VHF band.
Whereas FM broadcast is down around 100MHz, far enough away that it takes some different circuitry.
Because of this, another good option would be a standalone weather radio.
hrhoward May 10, 2018 12:48 PM
Only thing I have found is a marine head unit.
http://tinyurl.com/yc7yct33
If it was black, I'd probably already have it. Can't abide with the white.
