The Green bastard
Old 02-15-2019, 11:01 AM
Fastercat's Avatar
I got the 4.6 pulled this morning 😊❤️ Bolted to my stand
I
  #42
Old 02-15-2019, 03:27 PM
Fastercat's Avatar
Originally Posted by Saturnine
You sure one isn’t a trans cooler and the other an oil cooler?
I have one one of each on my 01’ but I’m not sure if it was factory installed or by the PO at some point
your right saturnine. I was too tired and didn’t look close enough
  #43
Old 02-21-2019, 10:52 AM
Fastercat's Avatar
Got a screaming deal on a plasma cutter. Can’t wait to build my sliders and rear bumper now!
Pulled out the powerplant to fix the contractor.
Curious about using these p38 headers
The inside of the flange to pipe looks very restrictive, I could probably weld and grind them smooth. Would take some time tho.
Started pulling the ancillaries off the 4.6
  #44
Old 02-21-2019, 09:37 PM
Received 1,465 Likes on 1,196 Posts
Great progress and jealous of the plasma
  #45
Old 02-22-2019, 03:47 PM
Fastercat's Avatar
I started to tear my 4.6 down. I’m not that impressed at how dirty it is
Perhaps someone with more experience could tell if this much caked on ( burnt) oil is normal?
I haven’t pulled the bottom apart to check the bearings yet
This was awesome........... found it in the cylinder head, above an intake valve. Looks like it was there for a bit. No question about rebuilding heads with new valves now.
  #46
Old 02-23-2019, 05:11 AM
The Deputy's Avatar
Received 1,160 Likes on 836 Posts
That crusty build-up is pretty common nowadays, with the increase engine operating temperatures over the years and lack of quality oils being used...you get this result. Especially as vehicle ages, the owner is less likely to spend the extra bucks on quality oil and when you take into consideration the cooling system is not working at 100% efficiency anymore. Everything use to run at 180° "back in the day", now it's common for engines to run in the 210° range, or higher. Remember going to a oil seminar several years ago...(yes, l lead a very exciting life...lol)...and they talked about oil breakdown for each addition 3° of engine temp with dino oil. But, with the increased protection from synthetic oils...it was cured (mostly). This is why, in my humble opinion, you should never stretch out your oil change intervals if you are using non-synthetic on a modern engine (1990 or newer).
The hose clamp is just an extra, all high dollar rovers have this option. If you have a cooling system failure, you just pop the upper and lower manifolds off, retrieve clamp, repair leaking hose and off you go! The British...they were way ahead of the game in this brilliant type thinking.
  #47
Old 02-23-2019, 05:23 AM
The Deputy's Avatar
Also, while doing engine work or oil changes...you should be wearing black nitrile gloves. With the additives and such in the synthetic oils, fuel dilution and micro-materials from inside the engine...you are taking a great risk at contracting some types of cancer.
​​​​​​​ Brian.
  #48
Old 02-23-2019, 09:15 AM
Fastercat's Avatar
My wife would appreciate the gloves too. Lol thanks Brian
  #49
Old 02-23-2019, 12:28 PM
Saturnine's Avatar
Get these!
Amazon Amazon
  #50
Old 03-01-2019, 05:09 AM
Fastercat's Avatar
P
Damn curious what these little grind or port marks are on the intake ports. Anyone?
The cylinder walls look great to me. Still see cross hatching, don’t feel a lip on the top
pulled the heads off last night, thanks to Brian’s advice was no problem. And I did use nitrile gloves thanks to you guys. I only pulled them off for the pics
Quick Reply: The Green bastard
