Operation Magpie.
#561
#562
Received 1,160 Likes
on
The problem with bending the bumper back to its original shape would be...taking it past the point of original. You need to bend it up farther than its original position, because it will want to flex back to its bend position. You basically need to bend it past its original position, so when it flexs back...it ends up where you want it, original shape.
And in order to do this...you'd need to remove headlight, lower plastic piece and fender (or just remove fender bolts along hood and one in front lower corner and gently lift a few inches out of the way, blocking it up with a piece of wood). Another problem is keeping the rover from lifting off the ground, while jacking the bumper. Without tie-downs in the floor, you'll have to use your imagination on getting it strapped/chained down somehow. Maybe you'll get lucky and it will bend with just the weight of the rover fighting the lifting motion, it really doesn't seemed to be bend that bad. Me, l'd cold bend it without heat. But, if that doesn't work...then heat along top piece while lifting very outer edge of bumper (at least it looks like the end cap is somewhat straight to get a 4X4 block of wood on it). Just be careful and stay clear of anything that will go bad quickly.
Brian.
Brian.
#563
Hmmm.. thanks for the tips Brian -- I appreciate it.
Not sure if i am going to even bother with it, i might just sell the bumper for some profit and get / make what i really want. For some reason, the hoops on the top side just look weird to me in general so... yeah
Just started a new job a few weeks ago that has all the tools i could ever need at my disposal so i'm thinkin now is the time to just build one!
#564
#565
#568
on
Problem...with that^^^^...is the vehicle is just going to come off the ground. That bumper is probably strong enough to support the weight of that rover...so it is just going to lift the wheels off the ground. You would have to anchor the frame work of the rover somehow, to keep this from happening. Unless you wanted to heat the bumper while applying lift/pressure from hyd. jack. If you decide to use heat, use long patterns/strokes of heat, so the bumper doesn't bend in only one spot...you'd essentially want it to bend evenly.
Brian.
Brian.
#569
I fixed a bumper on a Jeep by using a Uhaul Car Hauler trailer. We strapped it down from the frame to around the trailer cranked it down extremely tight, then used a bottle jack on the bumper and we got it straightened out in no time.
As long as you can anchor the LR down then you should be able to place a block of wood under the bumper and jack it up slowly.
