No heat
FYI the heat in these things is not great even when it works. In a '91 you probably have the old lucas glass fuses. That is most likely your problem. The fuse panel should be in the center under the dash, cover comes off with two *****. Often the fuse holders and connections get a little corroded, just fiddling with them can fix it. If a fuse is blown you need the lucas glass fuses, they are slightly different size than the standard american.
Evian
05-03-2008 05:10 PM
