Defender TD5 90
Hi
My engine keeps cutting intermittently whilst driving. Cuts for a split second, engine light comes on and then goes off again. Not near a dealer so can't check diagnostics. Any suggestions as to what would cause this? Happening more frequently each time I drive. |
That will be oil coming down the injector wiring loom down into the ecu.
Needs a good clean with brake fluid or renew. Hope this helps? |
| All times are GMT -5. The time now is 08:46 AM. |
