engine identification
Does anyone know where I can find some sort of resource that will help me to identify an engine?
I've got a Defender with a V8 Petrol engine in it... I believe it is a 3.5L (but I suppose it could be a 3.9L). The vehicle had been pieced together from a number of others, and I do not know the source of the engine. I have located the serial number on the block and I would like to know if there is some resource that I can referance which will tell me exactly which engine this is and when it was produced; so that I can be sure I'm referancing the correct shop manuals. Thanks, Punter |
RE: engine identification
Best contact your Rover dealer or shop, I don't believe the engine serial number will tell you anything I know the VIN will tell you what the truck came with.
Wish I could be more help. Mike |
No problem!
The number on the left bank of the block will start out with 2 numbers and a letter. This is the engine code and will tell you engine size and application. Here is a quick list! 31D--3.5 litre 36D-- 3.9 litre Range Rover and Disco 1993-1995 38D-- 3.9 litre Range Rover 1989-1992 40D-- 4.2 litre Range Rover 1993-1995 LWB only 42D-- 4.0 litre P38 Range Rover 1995-1998 46D-- 4.6 litre P38 Range Rover 1995-1998 50D-- 4.0 litre Disco Series 1996-1999 manual and auto I doubt you will need the Bosch numbers, but if you do....... |
What is an engine starting with S70D?
Originally Posted by Old Off Roader
(Post 17057)
No problem!
Good imformation thx
(Post 17057)
No problem!
Engine identification number
Is anyone out there able to help me figure out what my engine identification number means do I have a 4.0 or a 4.6?😖
Engine # S87D01088A |
Engine numbers
Can anyone help have an engine from a 1972 Range Rover but only numbers I can find on engine is as follows 31D PH1 026 R. CR8. 1311
Originally Posted by tes1368
(Post 779553)
Code V8
Bonjour je cherche à savoir à quoi correspond le code moteur 08D28108A
CR 9,37:1 merci |
| All times are GMT -5. The time now is 08:52 AM. |
