Defender Talk about the Land Rover Defender within.
Puma Instrument Cluster Problem
Old 08-17-2017, 07:58 AM
Uss's Avatar
Uss
Uss is offline
Default Puma Instrument Cluster Problem
Hi, I am new to the forum and was wondering if someone has had a similar issue & a solution.
The odometer display on my cluster has faded out so I bought a new cluster. When the LR workshop tried to program it after the install it went through the whole process but wouldn't let it start so they put back the old one till a solution is found. The workshop uses SDD 150.4 software.
The part that needs to be replaced is Instrument Cluster/Clocks: YAC 502810 PUY. The new part which was not being programmed is FH 1210849BB. I have attached a photo of both with part labels which may be able to offer more details & information. I bought the part in UK and was advised it is compatible.
Any assistance will be much appreciated
riko suave
03-18-2009 04:34 PM
Panic
02-23-2009 01:41 PM
CandiMan
10-30-2008 01:39 AM
coldfrez
10-01-2007 09:49 AM
Greg
08-08-2007 04:47 AM
Quick Reply: Puma Instrument Cluster Problem
