1994 disco front sway bar?
DI's did come with a front Anti Sway Bar. Most likely your was removed.
The first pic shows the ASB mounted to the 2 brackets that are welded to the frame.
The 2nd pic shows the 2 LINK END mount points on the axle.
And the last pic is of the ASB removed, but even removed you will always see the 2 brackets ON THE FRAME.
Pick-n-Pull keep checking you should be able to find a replacement bar but also get the straps and hardware plus the end links and hardware.
I would at least add Poly bushings front and rear.
Presently in the process of pulling parts off a 95 D1 at a Pick-n-Pull, a street roll over with both anti-roll bars missing, go figure? Bad enough handling with factory ant-roll bars. If driving on the street.use the bars but add removable links if you must have full suspension travel off road but not on the street for yours and others safety.......~~=o&o>........
JimmyG
05-28-2014 06:38 PM
