1999 discovery1 antilock module
Somewhere here I was following a thread quite a while back. someone told of a bleeding procedure at the lines on the antilock module that worked. I had to replace the booster and now need to clear the code on this item. Does anyone remember where I could find that discussion again or know the procedure I need to bleed the lines at the antilock module? Thank you.
I should clarify I don't believe my issue is properly described as a code, it is the antilock warning light.
Mecevans
08-09-2015 02:30 PM
srfnsno99
08-26-2011 11:25 AM
