300tdi disco Custom Speakers Boxes 6x9
5 Attachment(s)
I'm 21 and i love my loud music in my cars. So when i got my disco i had the problem of installing 6x9 in the back of my disco. I managed to put 5 1/4" components in the back pilers with slight modification. But wanted some 6x9 4 to be precise. So i decided to build a custom box above the back door and i removed the near side dicki seat to mount my amp and power cap. I have a twin 12" active sub in the back on a fast plug so i can remove it when i need too. Im just waiting for my sub to come back because i had a problem with the built in amp on it but that should be back on monday so ill up load pics when i put it back in. I have some pioneer 10cm speakers in the front powered off the head unit. The full install is very very loud.
1 Attachment(s)
Slick. Others have taken a different path. Turn it up and make the mud jump right off the truck...
What mounting points did you use to keep it secured up there?
Pretty sleek though I'm curious why you mounted in the rear opposed to a speaker bar in the middle of the truck. Similar to what the Jeepers do
Vertically Driven Products OVERHEAD SOUND BAR - JCWhitney |
Originally Posted by keoni004
(Post 385693)
Originally Posted by honda50r
(Post 385815)
My replacement sub should be here shortly so i will upload more pics when install of my whole sound system also i'll upload a video
Originally Posted by djchub91
(Post 385893)
One of my mates liked ot so much that he got me to build one for him identical.
(Post 385914)
Yeah, you've really got me scratching my head, coming up with my own plans for a sub/amp enclosure. I'd love to get dimensions and a total weight of your setup the next time you take it down, in addition to the mounting points. It looks like you used plywood? I was thinking along the lines of MDF, small amp and two small subs, but that's going to be a lot of weight up there - probably too much.
3 Attachment(s)
Here is the rest of my system. the wireing is just temp as i need to make the boot floor join the sides again if you no what i mean lo
