Sounds like you're on the right path finally..
Take that starter apart, Clean it up and get it working again.. Or just swap it for a new one.. John |
almost there......
Well, we are almost there. everything is moving in order except now it wont start based on a perceived fuel delivery issue, spark tested, checked fuel in rail and pressure good. injectors are not working now. did i trip a fuse because of the battery being disconnected?
Originally Posted by Viper61
(Post 357744)
Helpful post. Do you know where the starter relay is on the passenger side? I have a '96 disco as well.
I also have a 94 and had a similar issue. If you trip the alarm the engine will turn over but not start. You will not get power to the fuel pump or coil. I don't have a remote so I had to disconnect the battery to reset it. In the tech section there is a write up about bypassing the alarm just in case. Hope this helps.
My mechanic friend disconnected the security relay on the passenger side and re-set the computer. I'm running w/o security, but I'm running.
| All times are GMT -5. The time now is 06:16 AM. |
