Originally Posted by 96 WHITE
(Post 550563)
How hard is it to replace the VSS on a 96 Discovery and where is a good place to get them?
Mine started the cutting out about 50-55mph and it be okay. Sometimes I could drive a few hundred miles no problem. But it started getting worse as described in above post, even at a stop light taking off, I wanted to burn my truck at times. If rovahfarms doesn't have it, Land Rover parts, spares, Land Rover accessories, all models - speedometer transducer more expensive here to. Not sure if yours is the same as a 98 or not though. It's also called a Speedometer Transducer . My model no. YBE100540 Verify with one of the above poster. |
GEMS models 96 - 99 1/2 are roughly the same throughout except when it comes to the Evap system (can, fuel pump and purge valve) and window hardware.
