97 4.0 high idle and overheating
Was the software pretty straight forward? Mac or PC?
Thanks
It took me a long time of troubleshooting to get it working as it wasn't working for me. Ultimately I needed to update the firmware for my cable and then it worked as designed. Needed to download software to update firmware and then change a setting for baud rate to get the firmware to update. After that was two seconds in the command prompt and my idle was stable 700.
That’s wonderful to hear, and congrats on the success!
If you have time by all means please do tell of the steps needed in details as I would very luch like to resolve this once and for all. 700rpms sounds like a dream.
Which cable did you get that required the firmware update?
I have an older device running Windows 10 and I want to get it ready.
Thanks
Thanks
I used this cable
Steps:
- plug in cable and follow instructions that come with it to setup obdwiz softwade
- plug into car and verify obdwiz software is working as it should so you have a baseline that drivers are setup etc.
- on obdwiz website find latest firmware software install and open, change baud rate to 162000 or something like that. Can use trial and error until it works
- get gems.exe file and save somewhere on your hard drive (I saved on c:\ root folder for ease in finding)
- open device manager and look under com ports with your cable plugged in to find the com port your cable is using - mine was com5
- make sure obdwiz software is disconnected or won work
-cable should be plugged into computer and truck with truck not running but key all the way over so oil light is on
- open command prompt
- if saved in C:\ go:
Cd\
Then gems comX reset (where comX is the port from devmanager)
That did it for me. I can send links to gems.exe and firmware update software if you can't find once cable is setup and working
Steps:
Cd\
GEMS software: http://www.flemcodesign.com/files/GEMS.zip
Firmware update (ver 4.5.1) https://www.scantool.net/downloads/updates/obdlink_sx/
Drivers should install when you setup Obdwiz with the instructions that come with the cable. But if not, you can find the drivers here:
https://www.ftdichip.com/Drivers/VCP.htm
Hatchetjack (11-18-2019)
