-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   97 5spd ques (https://landroverforums.com/forum/discovery-i-39/97-5spd-ques-39276/)
JumPeR04 Mar 19, 2011 09:57 PM
97 5spd ques
what transmission fluid do you put in a lr 5spds and the slave value or is it the same for the auto... i am trying get it up and run right since i totally mine 99 disco 1 :(...
thehun Mar 19, 2011 10:55 PM
According to my handy dandy amsoil guide...it takes syn atf
antichrist Mar 20, 2011 01:27 AM
The owners handbook lists ATF, however Land Rover released a Technical Service Bulletin stating to switch to MTF (Manual Transmission Fluid).
I run Redline MTL in both of mine.
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil
JumPeR04 Mar 20, 2011 08:47 AM
also it is grabbing at the top so does that mean it going out or what since i never owned a 5 spds in my life... how many quarts does it take too... thanks guys for the info
antichrist Mar 20, 2011 11:12 AM
What do you mean "grabbing at the top"?
Capacity if listed in the owners handbook.
thehun Mar 20, 2011 02:15 PM
im sure his talking about syncros
antichrist Mar 20, 2011 03:08 PM
Well, I can say from personal experience that the baulk rings (syncros) are happier with MTL.
JumPeR04 Mar 20, 2011 05:22 PM
when you push the pedal it is grabbing at the top not the bottom what i was told
jafir Mar 20, 2011 06:04 PM
Sounds like you are talking clutch, not transmission.
Banzai Jimmy Mar 20, 2011 06:26 PM
X2 on the Redline MTL. It's good stuff and worth the extra cost. If you haven't been using it, the tranny will behave better after swapping to it.
