97 D1 steering NOT
Too much air in the tires (fronts at least) will definitely make it very twitchy - I was chasing a wobble in my front end for weeks, checking and rechecking everything, except tire pressure. Lowered it and the wobble disappeared.
Read a neat trick - draw a straight line across your front tires then roll backwards (or forwards) a couple revolutions. Chalk wear is even? You're good. If it's worn in the center but visible on the sides you're at too much, if it's worn on the sides but not in the center you're at too little. Check that against the recommended pressure for the Discovery.
DiscoBritney
12-19-2011 06:24 PM
jycsalas
04-17-2009 02:21 AM
Evian
08-18-2005 11:34 PM
