97 Disco Uh-Oh
#21
#22
Got two gallons of Rotella T (saving the T6), filter wrench, and 1-1/8 wrench the size of my arm.
I hate that all I can think of while laying under there, looking up, is it's going to come down off the ramps and crush my head. (Maybe that's a good excuse for a lift )
I don't think the oil light came on while I was driving it onto the ramps though.
Big truck, small garage.
#23
If you put both ramps on right side(which you did) it makes the oil drain incline down slightly, and easier to crawl under with the grease gun for drive shafts. If you come out clean you missed something. If oil that comes out looks bad, change again in 1000 miles, a soft acting flush. If what comes out has milky water in it, HG issue. So in your case, hope for dirty oil.
Would measure any roof rack carefully.
#24
on
You do know that empty the Discovery weighs about 4500 pounds or so. You have it resting on plastic ramps? I would be afraid of that as well.
Get yourself some good quality jack stands to support the beast. If you have the original bottle jack, they are more than capable of lifting it to get it up on jack stands, otherwise buy yourself a good quality hydraulic bottle jack or a good floor jack rated at at least 2.5 to 3 tons or so.
#25
Yeah that's what concerns me, but they do say they're rated to 12,000 lbs. I did try pushing and jumping on it all over to check stability...
My concern with jack/stands is that the garage floor is on a slight incline. About 1 degree or just enough to make it roll very slowly so I'd be worried about the jack/stands falling over too. I guess if the back wheels were planted and the center diff was locked it'd be ok.
#27
#28
#29
Man you got the wool pulled over your eyes on this one. You should seek legal recourse before doing much work. You are likely in for a long expensive road and will likely lose money hand over fist. That's why I say seek legal recourse first before sinking money in you can't get back. Good luck with this man. If you get stuck with it there is plenty of help here. You are just gonna need deep pockets. Hopefully if you are stuck with it the engine won't be shot.
