abs light doesn't come on
my 97 d1 abs light always worked properly light on on startup after a few rotations goes off,i recently cleared cobes (p1316) after cleating no more light on startup.when i turn the key to 2nd pos i don't see the abs light any insight would help;thanks
if I recall, the ABS light is an old school bulb. may have just burnt out.
is there any way to tell if abs is working
Originally Posted by rjlsierra
(Post 871195)
i understand that but is there a test that can tell me the unit is working will a diagnostic test tell
https://www.rswsolutions.com/index.p...code-procedure
I guess you could try the blink code procedure. I doubt it will illuminate, but maybe we'll be surprised. All it takes is a cheap piece of wire. |
can you explain how to do that and what to look for.thanks
(Post 871295)
