Adding fog lights to non fog light equipped discovery I
Hi All,
I plan on adding factory fog lights to my SD. I saw that it has the connectors for the fog lights by the headlights, but when I pulled the dash button panel there was no connector for the switch. Anybody have any ideas? Is the connector there, but hidden? Thank you in advance. |
That is strange, I pulled the ceiling concole down in a no sunroof no home link disco and the plugs were there, maybe it is hidden?
If it is tucked away, should be a four wire connector with Red/orange, red/brown, black, and blue/purple wires. Never trust a color blind electrician under the dash....
If the wiring is there you may also need a relay and fuse
Thanks!
I'll look tomorrow and let you know the results.
Abranb |
