Alright boys 3 inch suspension lift time cheapest price?
on
I am on a budget so shoot me some cheap ideas .
Go ahead and dress it up with a biggass lift and get some killer rims as well. That will make it sell quicker when you put it on Craig's List after you cook the motor.
Then the next owner can join the forum to find out how to fix the real problems after you spend your limited funds on looks and ignore the real issues you have with it.
2" lift spacers on a worn out coil sprung disco is raising the center of gravity and the coils and shocks are likely already shot.
Call Justin at Lucky 8 and get Terrafirma HD kit if you are going to tow this boat or anything else often.
It will save you from ending up on the ditch with your rover and boat
Gorilla, if you absolutely have to have the cheapest UKoffroad on Dweb is selling that RoversNorth spacer kit for $40 shipped. You won't find anything cheaper than that.
DiscoWeb Message Boards
Yes I am pulling a 23 foot boat in and out of the water with it. I just decided to go two in spacer that I showed earlier. If I don't feel comfortable with it then I'll buy 2 inch lifted coil springs. Last question. No I need extended shocks if I get the two inch coil spring set?
As far as shocks the effective travel of your front shocks will remain unchanged due to the bottom mount being on the spring perch which will be lifted 2". The rear will have 2" less downtravel since the shock mount positions remain unchanged, whether you use spacers or springs.
