anti lock light on
anti lock light on
The anti lock light on the dash is on and doesn't seem to go off less I turn the key off. I tried the blink method by jumping pin 5 and 15, tried using a paperclip and a small wire, neither worked. I don't know if I was supposed to remove anything before I tried the blink method or not. Would like to have abs, only had the vehicle for a few months and the light has been on since I had it. I hooked it up to autel 619 scanner but it said it couldn't retrieve and abs codes. Any help is appreciated thanks.
Maybe obvious, but be sure you have the jumper wire in pins #5 & #15 in the OBDII connector in the right place.
That connector is c2083 and it reads upside down. TOP from the LEFT starts at pin #16. BOTTOM from the LEFT starts at pin #8.
Again maybe obvious, but I've seen this mistake made more than a few times.
So, turn the ignition switch to 0 (Off). Install the jumper wire, and then turn the switch to position 2. Cross fingers and count BLINKS.
Good Luck.
Good Luck.
Well finally got around to trying the blink method again. Starting to drive me crazy. No blink at all, might have flickered a little maybe I was starring at it and imagined it who knows. Tried pulling both fuses under the hood to at least kill the light no luck. I guess wishful thinking on my part. It's the only light on the dash so I figure I should at least clear it then move on to other things. I don't guess if I happened to fix the problem by cleaning the sensors and making sure there pushed all the way in will make the light go out? Is there a reader that will read the 98 abs codes or is that a dealer only thing? Thanks
