-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   ATF vs. 80wt - 90 in R380 (https://landroverforums.com/forum/discovery-i-39/atf-vs-80wt-90-r380-33076/)
Cosmic88 Aug 2, 2010 05:49 PM
Yet another opinion / experience based thread. Recently I heard from a friend that in the R380 Tranny he knew someone who used 80w -90 gear oil instead of the factory recommended ATF!
Now in my mind I'd stick with what LR recommends but ya never know...
I know the 5 spd. R380 tranny is pretty rare in the Disco but there are a few of us out there. Let the opinions fly...
Long Haul Aug 2, 2010 06:08 PM
I think you want to use 80w90 but you might want to wait for Antichrist to chime in.....hes pretty knowledgable on the R380s
Spike555 Aug 2, 2010 06:25 PM
AntiChrist uses RedLine MT fluid if I remember correctly.
I think there was a TSB on this and it said to use straight 80w, but I could be wrong, its almost happened before. lol
antichrist Aug 2, 2010 08:26 PM
Yeah, regular gear lube it not to be used in the R380.
There was in fact a TSB from Rover that MTF should be used.
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Spike555 Aug 2, 2010 08:30 PM
See, I told you there was a TSB. lol
Thank you for clearing that up AntiChrist.
Cosmic88 Aug 2, 2010 08:58 PM
thanks a lot for the input. I'll have to try the MTL 70W80 GL-4 when I do the tranny next.
What do you think when switching? Would you drain and flush completely or gradually flush over time?
tornado_735 Aug 3, 2010 01:40 AM
I'm curious about this as well, but I would suspect it's a straight flush and fill. There aren't any clutches to burn up like in an autobox.
antichrist Aug 3, 2010 07:14 AM
I just drained the ATF and put in the Redline. No flush needed.
If you want to be compulsive you can drain the cooler lines also.
