aux port on intake manifold??
Old 08-13-2014, 10:47 PM
XCELLER8's Avatar
Default aux port on intake manifold??
as some of you probably know, there is an aux port with a plug in it on the front of the intake manifold....its threaded.....I was wondering if anyone knows what size the threads are ? I was planning on installing a "real" temp gauge and would like to have the right on to just screw in there. thanks !
Old 08-14-2014, 05:33 AM
MM3846's Avatar
i dont recall the thread, but i have one in mine. you have a 98, why go through the trouble? just use a scangauge.
Old 08-14-2014, 08:33 AM
TOM R's Avatar
I also want to know, so I can but my fan switch there
Old 08-14-2014, 08:51 AM
MM3846's Avatar
theres a post or thread floating around here somewhere with more info.. thats how i found out about the port. all i know is that it is a SAE thread, not pipe thread. i think i kept the plug i can measure it when i get home.
Old 08-15-2014, 10:20 PM
XCELLER8's Avatar
thanks for measuring if you get a chance....I too am getting ready to go with electric fans
Old 08-16-2014, 08:45 AM
TOM R's Avatar
I searched and cannot find that thread size mentioned
Old 08-16-2014, 04:34 PM
MM3846's Avatar
i looked for it and couldnt find it, but i know i have it somewhere. i'll try another spot in my shed and see if it is there. i have to run to the hardware store tomorrow and i'll see what the thread is. pretty sure its 1/2" fine thread.
for the record, this is what my setup looks like:
flange pipe fitting (SAE) to pipe thread adapter, reducer to drop it to 1/8" and then finally the sensor. disregard the non-OEM bolt in my thermostat housing.. that was before i was forced to swap a new intake manifold..
Old 08-17-2014, 11:14 AM
MM3846's Avatar
3/4 x 16
Old 08-17-2014, 01:12 PM
HammerFit's Avatar
So this can used for mechanical temp gauge? I never got around to installing mine. I hated the fact I had to cut radiator hose for hookup.
Old 08-17-2014, 01:18 PM
MM3846's Avatar
yes. its also much more accurate than cutting the the rad hose.
Quick Reply: aux port on intake manifold??
