-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Bleeding Hydraulic Clutch System; Reverse or Standard Method? (https://landroverforums.com/forum/discovery-i-39/bleeding-hydraulic-clutch-system%3B-reverse-standard-method-74835/)
june82000 Jul 29, 2015 08:57 AM
I had an issue with no pressure on the clutch pedal. The clutch master cylinder in the car was sketchy at best so I have a new one to go in. I'm hearing that a reverse bleed may be the best way to bleed the entire system upon installation of the new master cylinder. Thoughts from experience??
