Brake line question
Re-plumbing my rear brakes in the truggy I ran into a small issue...... What size is the one on the right??? The line is the same size but the nut is bigger than the M10x1.0 that they used for the rest of the system... What a pain in the ass!! I'm thinkin I am going to have to special order an adapter piece now
http://img109.imageshack.us/img109/3117/photo21t.jpg |
If you're removing the ABS just cut it off and install an M10x1.
Originally Posted by antichrist
(Post 319660)
I'm not removing ABS at this time although I probably should have. - you responded to this post over on Dweb too - I'm gonna go pick up the adapter piece now.. |
For future reference it is M12x1.0 and I just bought an adapter at Autozone instead of reflaring the tube..
I trust you double checked to make sure it was for ISO bubble flare and not metric inverted flare.
(Post 319784)
Dorman/AutoGrade M12 - 1.0 x 3/16 in. male to M10 - 1.0 female bubble flare brake line specialty adapter (788-522) | Brake System Adapter | AutoZone.com_ |
Originally Posted by Jake1996D1
(Post 319797)
Yea I got the right part hahaha - here's the part number for those looking for it in the future
Good to know they have them. |
(Post 319817)
I figured you had, but I was only seeing inverted flare on the Autozone site. Then again I wasn't looking for a long time. Plus I was looking for a coupler rather than an adapter. I wasn't sure exactly what you were doing.
| All times are GMT -5. The time now is 04:56 AM. |
