Clink in reverse AFTER prob rebuild
Old 09-12-2010, 09:32 PM
ShortTom's Avatar
Default Clink in reverse AFTER prob rebuild
So about three weeks ago I finished the front prop rebuild with serviceable u joints. I sweated and grunted getting them in but finally the circlips got seated and the joints moved freely.
About a week ago I noticed a small clink when shifting in reverse, then I noticed that I get a pretty good clink when I let out of the throttle and come back into it hard, usually at highway speeds. I don't necessarily remember this happening before the rebuild, but I started the rebuild about a week after I bought it (thanks Tom for scaring the living life out of me about front prop failures) so it's possible I overlooked it then.
Question 1: Is it normal to have some a slight clink when shifting from park to reverse (such as from play in the diff)? I would guess not on this because it' doesn't happen every time.
Question 2: Did I muck up the front prop u joints? I made sure no needle bearings were missing, but I did have to plug pretty hard on those guys to get 'em seated. Aside from the clink I have no vibration or other performance problems.
Question 3 (assuming negative on the second): I have not rebuild the rear prop yet. Is it common to have to rebuild those around 80k? Also my rotoflex is showing a few small hairline dry rot cracks, will that cause popping?
Question 4: Any cracker jack ideas on how to pinpoint this noise? The props are of course rock solid to my desk-job weakened hands.
Question 5: If so on the rear prop needing u joints, should I drop everything and fix this?
Mucho gracias senoirs for your helpos!
Old 09-12-2010, 09:52 PM
lipadj46's Avatar
Sounds normal to me
Old 09-12-2010, 11:06 PM
lordmorpheus's Avatar
Ditto. I get the same noises at 100K. When I had my front shaft out to be rebuilt, and the transfer case in CDL, it made no difference on the noise. I am planning to replace my rear u-joint and roto-flex (no problems with either) just for the sake of it, but I would be willing to bet the noises aren't going to change with the rear driveshaft removed either.
I get the occasional click/clunk when shifting to reverse, and I have learned to drive to avoid the click/clunk by waiting for the transmission to shift if I let off the throttle completely, before giving it gas.
Old 09-13-2010, 06:42 AM
What year and how many miles on it? Did this happen as soon as you reinstalled the shaft, did you replace the centering ball and who's u-joints did you use?
Old 09-13-2010, 08:27 AM
ShortTom's Avatar
DiscoMike-
2003, 83k, don't really remember if it started then or was always like that, yes I did, and Neapco 1-0005, respectively.
Old 09-13-2010, 09:35 AM
its just drive line slack. keep an eye on the rotoflex though that will need replacment or rebuild soon.
Old 09-13-2010, 10:16 AM
ShortTom's Avatar
I love you guys...!
And I will be rebuilding the rear prop hopefully before winter. Any special tricks on that?
Old 09-13-2010, 12:19 PM
you have two options. rebuild it with u joint or purchase a one already built with a u joint conversion or you can just replace the rotoflex as is.
Old 09-13-2010, 02:46 PM
Did you also replace the centering ball? If not, that is your problem.
Old 09-13-2010, 03:40 PM
ColoDisco's Avatar
How many people have had the rotoflex fail on these?
I am contimplating removing it and putting in a U joint.
Quick Reply: Clink in reverse AFTER prob rebuild
