clutch refuses to bleed
(manual D1)
my clutch fluid clearly needs to be replaced... looking pretty dirty...
but when i tried to bleed it (as per RAVE manual) the old fluid simply refused to come out!
RAVE says;
1. Attach suitable tubing to slave cylinder bleed screw (done)
2. place free end of tube in a glass jar containing clutch fluid (done, using DOT4 as per manual)
3. loosen bleed screw (done)
4. pump clutch pedal, pausing at the end of each stroke, until fluid from tubing is free of air. keep free end of tube below surface of fluid.
...I was doing that fourth step, but after many, many pumps nothing had happened at all, except a tiny bit of fluid crept out of the bleed screw. I loosed it quite a bit, too.
Did I miss anything? Does this mean my slave cylinder is clogged/damaged?
RAVE says;
buttocks
12-31-2014 12:53 AM
flyingalexf68
05-09-2006 01:51 PM
