-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Cooling system overhaul, why can't things go smoothly? (https://landroverforums.com/forum/discovery-i-39/cooling-system-overhaul-why-cant-things-go-smoothly-42572/)
adigerol77 Jul 26, 2011 03:05 PM
Udate...Cooling system overhaul, why can't things go smoothly?
So soaked it in PB for 4 days, tore the rad out and fan for more room, whacked it with a hammer, heated it up and whack, bolt broke about an inch from the head into the timing chain cover so she's off for open hood surgery, I don't feel confident enough for bolt removal. Call me what you'd like.
So flushed the rad, changed upper and lower hoses, t-stat, started removing all the bolts on the water pump then wouldn't you know it, the long 1 that goes through the timing change cover into the block is frozen and more than likely, will snap off. So now I get to do it all over again when I have time and while I'm in there, I may as well do the upgraded timing chain and sprocket, gotta love our Disco's.
thehun Jul 26, 2011 04:15 PM
That sucks
Chris-bob Jul 26, 2011 04:32 PM
Alot.
wheelgarage Jul 26, 2011 04:58 PM
You should have started a bonfire and danced around it first....to please the LR gods....
LRD2&ME Jul 26, 2011 05:34 PM
Use a propane or butane blower. You can get them at Lowes or Home Depot. Heat that bolt up real good and then keep spraying PB Blaster on it. Try to tighten just a little bit. Just to move it with the grain, until you haear a light tick noise. Heat it lightly and then try and back it out nice and slow. Tightening a bit will regroove the thread that is breaking.
Danny Lee 97 Disco Jul 26, 2011 05:50 PM
When I was in the Navy (1971-75) we were taught the easiest way to break torque on any fastener was to turn it in a tightening direction first, then start loosening it.
I still do that and it almost always works.
LRD2&ME Jul 26, 2011 06:03 PM
Yeah tought me the same thing in the Marines.
adigerol77 Jul 27, 2011 12:48 PM
Thanks all, I'll let you know how it turns out.
ihscouts Jul 27, 2011 03:23 PM
Heck, if your doing the timing chain and sprockets you might as well do the cam and lifters eh.
Savannah Buzz Jul 27, 2011 04:36 PM
I just did my WP and that same bolt was stubborn, but moved along when I tapped the end with a hammer, while turning with a wrench.
