D90 Front Brakes
Old 07-06-2012, 11:27 AM
ValveCoverGasket's Avatar
Originally Posted by Jake1996D1
Yea I wish I could afford the fancy bubble flaring tool
i ended up picking up one for work on the RR as it made life a lot easier... after doing so i figured out that half the battle when making smooth and even flares is picking the right line material that's workable enough to flare easily...
check out the cunifer stuff at FedHill if youre making new lines. super easy to work with and doesnt rust.
  #22
Old 07-06-2012, 01:18 PM
antichrist's Avatar
NAPA has the copper/nickle line in 25' & 50' coils.
  #23
Old 07-06-2012, 02:42 PM
cool, probably the same stuff. i bought from FedHill just because they were the only source i could find for some of the oddball RR fittings that i needed.
either way, i wouldnt attempt using anything else for the lines given how easy that was to work with... and the RR system runs at a much higher pressure than conventional brake systems, so if it holds up to that...
a picture... just because hah
ok, ill end my thread derailment now
FightOnUSC79
11-26-2010 09:43 AM
acornhoek
07-24-2007 07:28 PM
1eyescooter
02-01-2007 11:12 AM
1eyescooter
01-15-2007 08:48 PM
brianaintright
07-19-2006 06:32 PM
Quick Reply: D90 Front Brakes
