Disco knock
Quick update, I haven't given up yet. Thank you for the guidance PT. I have not had time to get to the heads. I did try the aforementioned removing of the belt. and everything seemed fine. As far as the vacuum leak, I do agree there seems to be a leak. I have tried to trace it down with no avail. I can tell particularly off idle it stumbles a bit and seems to be dying for air. Any more help would be appreciated. Some more information, my wonderful gf just bought a 97 Disco as well, so I can pull parts etc if needed. Maybe its just my eternal optimism, but I just can't seem to get away from the idea of timing or other options along those lines.
It looks like Oil Separator - Valve Cover | Land Rover Engine Parts at RoverParts.com, it is located on the right hand valve cover, in a metal tube that pokes up, and a rubber hose slips over it. You can extract it with needle nose pliers, clean with solvent. It basically a baffle to allow just oil vapors to be drawn off. If plugged up, the oil PSI can make oil squeeze out of various seals.
I don't think its the water pump (but certainly won't rule it out completely). However, there are a few more updates. Did find a coolant leak in one of the hoses (the one above the left side valve cover by the oil separator) and noticed that there is definitely some arcing from the wires to the engine. Will try to work on those tomorrow and order the oil separator Monday.
So you have an oil seperator hose connection to the valve cover, with the hose attached, just nothing inside (may be pushed down inside)? Or missing the hose (other end would go to intake somewhere, to suck in the oil vapors - if not attached it is a vacuum leak).
Sparks can be seen easier this time of day with no lights on. Sometimes just bad boots. Sometimes need new wires. Can cause all sorts of hesitation, poor performance.
Correct, the hose connection straight to the valve cover with the hose attached and nothing inside. If it is pushed down inside it is way down in there and no way of getting it out besides removing the valve covers I assume. I really don't think there is anything there though.
I just replaced the plugs and wires. I will check the boots and wires when I can.
Thanks for the guidance.
Allen
Allen
