disco wheels
as I am finding out disco have there own stud pattern now mine has the cheese cutter wheels will the larger mags from the disco 1 fit on a earlier on as the 96 onwards to the pre 94's?? as wheel as the diffs because there stronger I have been told?
Originally Posted by dez5000i
(Post 486139)
I don't know what you mean by bigger wheels between 96 and 94. DI's all came with 16" wheels. It was not until the DII's that LR started selling them with 18" etc. |
I have a 93 disco1 with steal wheels what I ment was I want wider wheels for when I go off roading that's why I said about the diffs aswell?
wut.
just buy some black steelies. 5x6.5 bolt pattern. |
Have MRW make you what you want. Very reasonable for custom offset steel wheels
1 Attachment(s)
(Post 486149)
If so, they are the same width as disco alloy wheels, 7 inches. If you've got the narrower defender or series style 5.5 inch wheels, than adding the newer discovery wheels will help with the narrowness that you don't like. We didn't have Discovery in 1993, do they all have rear disc brakes? I know my 90 originally have drum brakes in the back. Most factory alloy wheels won't fit the drum brake axles. I've since put a 1999 D1 axle in the front and rear of my 90 so that I can run any wheels I want and to make it easier to find lockers and HD axles. |
(Post 486149)
2 Attachment(s)
Attachment 37228
That's my disco and wheels I'm talking about I was ment to get today buy got impatient and went and got yesterday went through some mud and stuff went ok Attachment 37229 |
A 3 door RHD, well lucky you! Australia? The wheels you have are the standard steelies that came with the truck, they're original. Your diffs are the same as all Disco's, they're good enough for 285's tires with lugs, maybe a little bigger. They're all open though, tire without traction gets the most power. Lockers help but then they put a strain on the axles.
Ashcroft has all the equipment for beefing up the diffs. What size motor in your rig? |
Yea aussie one 3.5 disc's front and rear and 5 spd
