Does this sound like a bad fan clutch?
#21
I dont know if this makes any difference, but I noticed that if i turn off an electrical feature when it is squeaking, it goes away. I have NO idea why it does this; the alternator is brand spanking new and im 99% sure that the squeaking is coming from the fan clutch/water pump area, not the alternator.
#22
Well, you live in the country, there must be wood sticks around that barn for something, just press one end to your ear and the other to things like the alternator, water pump, etc., and you'll find that noise. The change in electrical load changes the mechanical load the alternator puts on the belt system. It may not be the alternator (but new ones are always suspect because you most likely bought a reman unit from a parts store, not a brand new factory one). Rebuilt alternators by local shop is good. Rebuilt by mass market folks with el cheapo parts from China - high failure rate. You should also be able to slip off the serpanine belt and turn things by hand to detect any roughness. Belt route is important as well, check against the RAVE to be sure.
#23
on
#24
#26
#27
