Driver side mirror glass mounting adapter Help
I have purchased this part from Atlantic British
Mirror Glass Mounting Adaptor (Part # STC4625) - Land Rover body panels/fittings/trim exterior from Atlantic British The old one has the tabs that hold the mirror glass broken so this will fix it. But I have not figured out how to remove and replace this part. Has anyone done this and is there a trick to this? I am afraid of breaking other parts getting the old one out. Any tips would be appreciated. PS this is a 1998 discovery 1 |
if memory serves me well....the adapter just pushes in or snaps into place and the glass snaps onto the adapter.....the adapter usually breaks when you remove it so its a good thing you have one coming....let us know for sure how this works
Take it to a automotive glass shop, give them the parts, 10min and $20 later and you will be back on the road.
So I changed it. It was as easy as pulling the old one and snapping the new one in. Thanks XCELLE8
glad you got it fixed ....now on to ...?
Oil pan gasket, Valve cover gaskets, Intake gaskets. Find a sunshade assembly for the sunroof and a passenger rear mudflap and a good set of power seats my leather is pretty worn.
| All times are GMT -5. The time now is 05:48 AM. |
