Driver side wheel noise
Hi this morning I got in my truck and started driving and it is making a loud rubbing noise. Its worse in reverse than in drive. Two weeks ago I replaced the bearings, rotors and pads so I pulled everything apart to see if anything was wrong and everything looked fine. Any ideas? It sounds like something is catching.
Caliper sticking?
Funny you should say that. I just pulled the tire off again and the bottom bolt on the caliper is seeping brake fluid. Any ideas on how to fix or just replace. Its my fault because I wanted to save a few and bought centric calipers.
update!!!! I pulled the caliper and its still making noise. Anybody? Oh and it only makes noise when I am driving. I can spin the wheel all day freehand and no noise.
Cv bad?
Im not sure. I pulled it out and cleaned it up but i am not sure what it should look like.
Did you follow the RAVE procedure(proper torque and whatnot) for the wheel bearings?
Yeah. But I pulled them back off and reseated them with no luck.
| All times are GMT -5. The time now is 09:38 AM. |
