Engine missing/bogging while driving at 2000rpm!?!
Old 11-07-2010, 08:20 AM
According to the GEMS service manual if it will not idle but will run as long as the engine rpm are kept above 550 rpm then it is a bad idle air control valve.
  #52
Old 10-15-2011, 01:00 AM
huntercreation's Avatar
8th Gear
Symptoms seem to completely match mine. Plugs and wires are the cure. At mechanic this about 600.00. The heat the engine creates causes the wires to degrade quickly. Atlantic British will have the parts.
Patrick
  #53
Old 12-06-2014, 03:40 PM
snydesh's Avatar
Any update on this? My Rover is doing the same thing. 1998 Discovery. It is not fuel, it is ignition. Watching the timing light it just cuts out when you rev it up. Idles fine.
  #54
Old 12-06-2014, 05:26 PM
jbriggs's Avatar
Default Yes
I changed the speed sensor on the transmission and it fixed it.
  #55
Old 12-08-2014, 04:32 PM
nuclearw's Avatar
Originally Posted by booper169
Can someone please tell me where the crank sensor and where the vss is
VSS is under the vehicle, between the transfer case and the parking drum (drivers side). its a pain to get to but easy to rebuild (See the thread in the tech section).
Mine did this where it was bouncing between 2000-3000 rpm in spurts when my VSS was bad.
Easy test, unplug the VSS and see if your truck drives normal. You will loose the speedo so have a GPS or something for telling your speed.
someone else can speak to the crank sensor.
EDIT: should have looked for page 3... ahha
  #56
Old 12-08-2014, 04:33 PM
nuclearw's Avatar
You're issue is probably different..... the VSS is only an issue if your vehicle is actually moving
Brian Barr
01-13-2012 08:29 AM
booper169
10-24-2010 05:42 PM
meltdowndave
01-30-2010 06:56 PM
alex of minnesota
01-09-2007 05:03 PM
speedon
06-20-2006 03:14 PM
Quick Reply: Engine missing/bogging while driving at 2000rpm!?!
