-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Engine running hot (https://landroverforums.com/forum/discovery-i-39/engine-running-hot-46212/)
MrMetal Dec 27, 2011 03:16 PM
Engine running hot
My first real problem has reared its ugly head. Today my discovery's temp gauge started to slowly rise and after reading all the post on never over heating it I pulled over quickly. Got it to the shop I work at and the fan clutch is no more. While looking through past posts I saw someone say that the fan clutch setup from a 01 blazer fit. How has this worked out for the people that have done this?
Disco Mike Dec 27, 2011 03:25 PM
Any of the Chevy P.U, non A/C, Non H.D. clutches that are the same size work well. Just take your old clutch off and go match it to a new one at the part store.
Spike555 Dec 27, 2011 07:08 PM
The part you need is listed in the DI tech section.
Savannah Buzz Dec 27, 2011 08:41 PM
4 Attachment(s)
MrMetal,
If you were driving at 40 mph or better, it is not just the fan clutch that was making you overheat. Fan only makes a difference stopped or very slow. So check out radiator as well. As stated, the Chevy / GMC clutches are also 6 inch, reverse rotation, and the same thread as our water pump. You will have to modify size of bolt holes on stock Rover fan. If you want to experiment, junkyard has cheap ones (more Chevys than Rovers in junk yards around me). Also good for low dollar emergency no-Rover parts available type repairs (get me home to my shade tree).
hh65flyer Dec 27, 2011 09:24 PM
I used the info from the sticky and got what I needed from NAPA. Also picked up the larger bolts while I was there too.
You can read all about it in my thread:
https://landroverforums.com/forum/di...-clutch-45607/
MrMetal Dec 27, 2011 10:49 PM
Thanks for the info going to pick one up tomorrow after work. As for the over heating it only did it when I got stuck in stop and go traffic. Over 30 the temp would slowly drop. I'am already thinking of getting the radiator cleaned since Its metal and can be rebuilt with a new water pump and thermostat also. Don't really want any problems once I'am out and camping lol.
Savannah Buzz Dec 28, 2011 07:32 AM
Indy rad shop can hot acid flush and rod out the copper radiator, usually under $100. Helps a great deal, since previous owner may have used non-distilled water. Well water is worse, due to mineral content.
MrMetal Dec 28, 2011 09:57 AM
You guys were right. Got the fan clutch in today at work, let the truck run for a while and just kept checking on the gauge. Slowly buy surly the gauge just keeps climbing slowly and I do mean slowly, Scan tool showed the same thing. Checked for exhaust in the cooling system and nadda. Looks like the radiator is coming out and heading to a shop for some love.
Thanks for all the input guys, helped a ton. :)
Jake1996D1 Dec 29, 2011 12:08 AM
Had the same thing happen to me - new rad fixed her right up.
