Engine/trans/TC swap out all in one?
I know this might seem preposterous but I want to swap the whole drivetrain from a 96 disco to a 96 disco. Reason being is that the drivetrain is bad on one, but the body is good, the other disco is rotting out at the seams and the drivetrain is really low miles. I want to keep the engine/trans/TC together to do the swap. i am thinking of cutting out the rad support on the bad body one and pulling it straight out, just trying to figure out if that will fit back into the other one coming down and in. That or I was thinking of raising the body and dropping the undercarriage to the ground and using a couple low dollies to roll it out enough to drop the engine into it. Can anyone offer me any advice this way, maybe from previous attempts or if you know that I could do the engine and trans together but not the TC etc. I just don't want to set the trans and engine together with the torque conv. I know little about positioning the torque conv. Help?
Originally Posted by SMP2010
(Post 354995)
I've seen the tranny and transfer case pulled together, but it was put back in separately, just to make it easier to handle. Like Jake cut the good stuff out of the bad body if you want, but I'd put the new stuff in one at a time.
| All times are GMT -5. The time now is 02:39 AM. |
