Fuel pressure Regulator
Hey guys I need your help. I have a disco 1 98.she was running ok, then started to sputtered a little, the next thing she didn't want to start, I left her sit a few minutes later she started .I got her home and walked away the next day she didn't want to start, I check the multi fuel module, all good there, I'm told to change the fuel pressure Regulator. That's all good. So where is it. And anyone have any video on the subject help please
While it COULD be the fuel pressure regulator (which is the round, brass colored part with two fuel lines and a vacuum line at the back of the driver's side cylinder head), it is more likely to be your fuel pump. At least that is what you should check first since it is a much cheaper item.
https://cimg4.ibsrv.net/gimg/landrov...1354da66ab.jpg There should be a schrader valve on the fuel rail on the passenger's side of your engine. Borrow an fuel pressure gauge from an auto parts store. PSI at idle should be >32. |
The vacuum hose connected to the fuel pressure regulator, what does it connect to on the other end? My regulator is missing the vacuum hose all together. |
