-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Fuel Pump not activating (https://landroverforums.com/forum/discovery-i-39/fuel-pump-not-activating-49698/)
pinkytoe69 May 13, 2012 08:10 PM
Ugh
So, I backed the rover out of the garage and shut it off. Strapped a canoe to the top of it. Try to turn it back on, no sound from the fuel pump. Cranks, but of course it doesnt start.
Checked current at the pump connector when key is turned to "on" and it hits .1 amps. Fuse is ok. Check the current at the fuse and it is also .1.
Battery was low (I think I have a drain), so I charged it and re-checked. Same results.
Please help :(
pinkytoe69 May 13, 2012 08:14 PM
Probably irrelevant to the issue, but I bought the fuel pump 4 months ago from AB and have maybe 100 miles on it.
Spike555 May 13, 2012 08:42 PM
Bad relay is my answer.
Just for poops and giggles you reset the inertia switch right?
pinkytoe69 May 13, 2012 08:59 PM
Ive pressed the inertia switch about 46 times throughout the troubleshooting process :D
The relay would be my thought too, but I thought that was downstream of the fuse?
Just to make sure I tested this right...
I put the multimeter on mA and put the leads in the fuse connector. Turn the key to on, and check the reading?
Spike555 May 13, 2012 09:03 PM
Unscrew the bad light bulb, screw in the new light bulb.
That us as far as my electrical knowledge goes.
Jake1996D1 May 13, 2012 09:06 PM
Try fuse #6 under the hood - I didnt know it was a new fuel pump before I diagnosed it dead in the PM
And if that is the problem then you get to figure out what caused it... The REAL problem :)
pinkytoe69 May 13, 2012 09:15 PM
If fuse #6 is the 15A fuel pump fuse, then yeah its fine. Thats also the spot I tried testing with a multimeter and wasnt getting any current.
Its too early for scary talk! lol
pinkytoe69 May 13, 2012 09:23 PM
Would any of those relays under the drivers seat have anything to do with this?
Jake1996D1 May 13, 2012 09:25 PM
Well if you can read the little diagram under the cover then you were probably at the right place. Time to track down a relay - it may also be a signal from the ECU - is the vehicles security system working properly?
Jake1996D1 May 13, 2012 09:28 PM
Nope - passanger side behind the a-pillar trim piece.. It's the one that partially blue
