-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Harmonic balancer wobble (https://landroverforums.com/forum/discovery-i-39/harmonic-balancer-wobble-85701/)
TOM R Aug 21, 2017 10:51 AM
While doing my oil change and running the engine im listening to the belt chirp and noticing the belts not riding on the wear mark on the idler, crawl under the truck and im watching the blalncer pully wobble and the belts mov7ng back and forth on the pully on either side
i assume i need a balancer and i see there is a small chip out of the lip on it so guess it got smacked at some point
suggestions?
i tried a search without much luck except seeing that the balancer is like $300? Which cant be right and a used one to me is not the best idea since it could be the same
this does not seem to be a part listed with online retailers like for an american car
ihscouts Aug 21, 2017 05:27 PM
Try Paul or Will Tillery. When my crank pulley cracked at the key I tried both and Will had one. No where near $300, more like $30.
OverRover Aug 23, 2017 03:37 PM
Tom, I'm with you re: a used balancer not being a 1st choice, but ERR7373 is NLA from LR so it might be the only option.
Maybe a NOS in the US will turn up for you...I'll see if I can find one and PM you the results. Good Luck!
TOM R Aug 23, 2017 03:53 PM
Got one used com I ng from paul thanks
ihscouts Aug 23, 2017 05:54 PM
Cool, like looking for a curly haired gnat from 45,000 feet with one eye closed eh. It's a door nob of a part but when ya need one ya need one.
