Having problems
Having problems
So I drove the car today no problems at all for about 100 miles. it was driven in 50-40 degree f weather. Well I parked at my buddies house and when I left it is 36*F. All of sudden my rpm gauge isn't working and my battery light is on. I managed to get back home with no problems. Any input on what could be going on? It has a brand new alternator from when I purchased the truck a month or so ago. No problems prior. Hopefully someone can inform me of some fixes..? or known issues.
Drag out your multimeter and make sure you're charging voltage is correct. and check that little white wire that has a single speed spade lug connection to the back of the alternator, that is what sends the signal to the tachometer, rpm is measured off alternator frequency
check that alternator real well. grounds and wires. is it a cheap auto zone rebuild? i went through six of these they overheat easy and brushes get destroyed even when truck isnt hot at all. the loaction of the alt. just subjects it to a lot of heat. i had these same problems but start simple and check for corrosion and such at grounds and check wire placement is tight.
Patrick
10-17-2023 03:39 PM
