-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   help!! (https://landroverforums.com/forum/discovery-i-39/help-46632/)
disco 96 sd Jan 14, 2012 08:46 PM
help!!
where is the cam shaft position sensor on a 96 land rover discovery sd? ive ran the codes and the purchased the part. but ive yet been able to locate it. if anyone cold let me know it would be greatly appreciated!! thanks!!
Savannah Buzz Jan 14, 2012 11:29 PM
1 Attachment(s)
It's on the front of the engine. Here's the page from the RAVE shop manual, free download of the whole thing at link in my signature.
EricTyrrell Jan 15, 2012 01:41 AM
between crank and water pump
Savannah Buzz Jan 15, 2012 06:59 AM
1 Attachment(s)
No that's the crank shaft position sensor, which is in this pix attached.
Jake1996D1 Jan 15, 2012 07:54 AM
Climb under truck, locate oil filter, now look left on front cover you should see a harness . Follow the harness to cam shaft sensor attached by a single bolt I believe.
Good luck!
EricTyrrell Jan 15, 2012 11:16 AM
Oops, smoking too much crank...
yeah cam sensor is right between crank and water pump.
