-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   IAC/ Throttle Adjustment (https://landroverforums.com/forum/discovery-i-39/iac-throttle-adjustment-94936/)
Mo 3 May 24, 2019 03:26 PM
How do I properly adjust the throttle control is there a specific method or just adjust until it stops shutting off while idling?
hrhoward May 24, 2019 03:52 PM
Hi there,
If you don't have a copy of the RAVE yet, get it. Find a post by WaltNYC, he has links in his signature.
Instructions for mechanically adjusting the throttle linkage are in there.
Idle air control valve or throttle body could be dirty. Linkage could be sticky.
WaltNYC May 25, 2019 05:14 PM
I'd clean the IACV before I'd mess with idle. You can get yourself to a point where you'll need to re-flash your ECU if everything is not set properly. The truth is the ECU should set idle.
