Knocking from brakes
In mine the brake pad backing was "floating" and slamming onto the caliper housing. The pad was lifted by a sticky section of the rotor and hit the upper side and fall back and hit again wearing out a groove. the fix was to replace the whole caliper. yeah right!
I now insert a tiny spacer in between and the knocking is gone
Look at the brake pads to see if they "float" up and down. the new pads might be a tiny smaller.
If they float, I'll draw a picture of the spacer
SD
SD
