Leaking fuel line, where to buy it?
1 Attachment(s)
My fuel line is leaking when car is running (98 disco)
It is a fuel line that comes out of the fuel pump - the far right pipe in the picture. Leak is 4-5" down the line. Any one knows where i can get a replacement? Can i use something universal? Attachment 41710 |
You are going to have to make your own.
You can buy tubing by the roll. |
Any Napa or auto parts store will have fuel hose. You could probably splice in a new part with some b a r b e d fittings. You could also lop off those push to connect fittings and install some compression style. Dorman makes some.
Be sure you use the high pressure type, for fuel injection.
