ECU compatability?
Spike, by now I would think that you are aware that you can not swap an ECU unless you also swap the BCU from the same donor vehicle.
And yes they ecu's are programmed differently by Rover to meet new upgrades to the engine as well as emission standards.
As for the need to start a new thread, yes, you can do that or just realize you were given bad information and I just happened to find it so you don't waste too much time making your truck right.
Still hope you answer the questions I asked so maybe we can help you, that is why you started this thread, isn't it? May find the problems have nothing to do with the ECU.
Swap both the security ecu and the engine management ecu and it should work.
Edit: nevermind forgot about advance evap..
