-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Losing power at high speeds (https://landroverforums.com/forum/discovery-i-39/losing-power-high-speeds-36815/)
maudlinp Dec 27, 2010 08:10 AM
Just bought a '97 Disco I from a friend. Absolutely love it!!! However, on the highway going about 70mph it will randomly loose power. I don't know how to discribe it except that I can hear and feel it loose power and then it goes right back to normal. I looked for previous post to find the solution, but couldn't find any. Please help! Greatly appreciated!! - Paul
jdhuegel1 Dec 27, 2010 08:26 AM
First thought is VSS (Vehicle Speed Sensor) is failing. Are you getting any codes?
maudlinp Dec 27, 2010 08:46 AM
No, sir. I'm not getting any codes. Thank you for your reply! I'll check into it.
Disco Mike Dec 27, 2010 09:13 AM
I would go along with the VSS also, also dirty fuel filter.
maudlinp Dec 27, 2010 09:46 AM
Wow! You guys are awesome! Thanks for the quick replies.
groundandpound Dec 28, 2010 09:47 AM
Power loss....
This was the first issue that I had that ultimately led to a fuel pump replacement. However, I "ignored" it for about 3 weeks, and replaced the fuel filter at the same time as the pump.
Hindsight and all that - I would listen to Disco Mike and start with the filter.
disc5995 Dec 28, 2010 01:23 PM
My problem is high RPM (2500-3000) at 70mph, what can be wrong?
Check RAVE again, there is no serviceable fuel filter for D2, so change fuel filter is not an option.
groundandpound Dec 29, 2010 09:25 AM
power
Your filter "sock" is attached to the pump, in the tank. As for what specifically is causing it - I'm at a loss as well.
For $90 you can get the Airtex replacement, with the sock and swap it out (30 minute job MAX) to see if that's the issue.
That is what I ended up doing and it corrected my issue.
Or the VSS route. At this point, with no codes or additional information...there really isn't much else I can think of.
Of course, others may say that 70 is only for passing :-)
Hope you figure it out!
Chris-bob Dec 29, 2010 11:32 AM
Could you perhaps be hitting the rev limiter....Just a thought.
Spike555 Dec 29, 2010 07:18 PM
You need to post your question over in the DII section.
All DI's have a replaceable fuel filter.
