Lubricating
how many nipples do I have....no, thats bad, where are the lube points on my 97 DI? Thanks, the tech manual tells me to lube them but not exactly where they are.
Cheers, Eoghan |
we just have them at our shafts....and if you replaced your tie rods...your tie rods
Originally Posted by thehun
(Post 234268)
YOU HAVE NIPPLES ON YOUR SHAFT??? Sorry, couldn't help it. When I replaced my tie rods, I specifically got ones with grease fittings. I dont know why they would make them(or u-joints) without. |
Crawl under your girl and get real intimate, caress every inch which your hands looking and feeling for lube points.
Make sure you feel the tops of the shafts too, some nipples may be ontop depending on the rotation of the shaft. |
| All times are GMT -5. The time now is 02:05 AM. |
