-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   M/T lubricant?? (https://landroverforums.com/forum/discovery-i-39/m-t-lubricant-53930/)
Disco28 Nov 18, 2012 11:06 AM
Originally Posted by SSL9000J (Post 357994)
Silly question: why would anyone recommend using ATF, automatic transmission fluid, in a manual transmission?
That is what the manual calls for on a 94 Disco, there is also a TSB on the fluid used in an R380. LR says to switch it to MTF but you can't find it anywhere. A lot of people have switched to Redline MTL which I am considering. Right now I am running ATF.
ValveCoverGasket Nov 18, 2012 01:30 PM
there are other modern transmissions (a few domestic ones come to mind first) that call for atf also. i think its partially for mileage reasons (atf being thinner and lighter) and possibly for shift feel as well.
Disco28 Jan 9, 2013 09:04 AM
Not only is ATF recommended I had a situation using gear oil in the R380 and Fifth gear exploded ending it's life (it was rebuilt and less than 6 months old). I found a used one and immediately replaced the fluid which was gear oil. These transmission are very sensitive to what you put in them.
antichrist Jan 9, 2013 03:36 PM
ATF hasn't been recommended for the R380 since 2000.
Gear oil and MTF are not the same thing.
archaeology_student Apr 20, 2013 11:22 PM
Probably had to do with the additives used back in the days that it was recommended by the manufacturer.
Additive packages in oils change over time, what was good then might be bad today. It is like trying to find Transmission fluid for Series Rovers. Certain fluids did not impact the yellow (brass) metals in the transmission, but the additives have changed spec and end up eating the yellow (brass) metals and causing catastrophic failures.
Think of oils, greases, and other fluids like food... most people these days look at the details on the back or side of the packaging of what is inside them, rather than what is stamped on the box package.
My $0.02
On another note, does anyone know where a lay person can find LR TSB's?
Savannah Buzz Apr 20, 2013 11:39 PM
start with TSB & recalls tab at top of page
archaeology_student Apr 20, 2013 11:44 PM
Savannah Buzz... I must be getting old! Thank you :)
Shiftonthefly1 Apr 21, 2013 05:36 AM
Name one Land Rover part that isn't sensitive. Hahah
jafir Apr 21, 2013 07:32 AM
What about the LT77?
Savannah Buzz Apr 21, 2013 08:46 AM
re: Name one Land Rover part that isn't sensitive.
Heat gauge.... and that gas gauge shows no mercy!
