MAF sensor O ring
What size O ring goes on the MAF sensor connection to the air filter?
1 Attachment(s)
I don't think there is an o-ring on the D1. D2 has one.
i could have sworn there was one on mine also... havent had that apart in a little bit though
Yes it does take an O ring. No idea what size, take the box and MAF down to NAPA and find one that fits. Rover probably gets $10 for the damn thing.
Yup, as HB said, there is an o-ring. I'll see if I can measure my spare when I get home unless someone beats me to it.
Looks like it is 1/8"thick and 3 3/8" outside diameter(which means the inside diameter is 3 1/8").
Hello old thread,
I just replaced my MAF on my 04 D2 and there was no o-ring on what I removed (stock original) and no o-ring in the MAF package. Where should I be looking for it - on which end is it fitted (the input or the output)? Both connectors are sleeve-type connectors and fit tightly. The output sleeve is held in place with a squeezing hose connector, and the input sleeve is part of the air cleaner lid and holds the MAF sensor with clips. Thanks! |
It goes on the MAF input end between sensor and box
I just replaced my old MAF with a new-in-the-box MAF. I called & asked the same thing as I didn't have one on the truck & there was no new one in the box. I was told there's not one on the D1.
Originally Posted by TOM R
(Post 439595)
Thanks again to everyone on this forum for all your help. /r |
| All times are GMT -5. The time now is 08:18 AM. |
